MK3.5 self-test and calibration without filament sensor
David Crall
(@david-crall)
The filament sensor on my MK3.5 failed.  The display kept telling me that the printer was not calibrated, but it was making good prints, so I did not address the issue.  I simply turned off filament sensing in the menu.   It swallowed a broken filament below the extruder gears so I can't use the unload function to remove the filament.  I removed the nozzle tip, but there is nothing exposed that I can pull on to remove the fragment.  My plan is to heat up the hot end and push the fragment thru the nozzle with a wire, but the hot-end wont heat up.  When I try and use the unload or pre-heat functions to heat the hot-end, it reboots and displays a message that the printer has not been calibrated.  I updated the firmware last month and it has been working fine with the filament sensor disabled.  How can I heat the hot-end so I can clear the clog?
Dave
Napsal : 25/01/2024 5:22 pm
