how does BBF work with MK3.5S+ for a firmware update
Payette
(@payette)
I am unable to find the hex file for the latest firmware update 6.0.4
I seem to only get to download a BBF and I am uncertain as to how that gets me a hex file that a can flash
Best Answer by Chip Wallace:
If you have and SD slot on the left of the screen, then you don't have a MK3.5.  The MK3.5 upgrade kit replaces the Rambo with the Buddy board, and a new screen that has a USB port on the right side.
It sounds like you just have a MK3 that you at least partially upgraded to a MK3s+.  The MK3.5 is a completely different machine.
I believe you need this firmware seen below.
Posted : 31/07/2024 6:37 pm
Marcel Karger
(@marcel-karger)
RE: how does BBF work with MK3.5S+ for a firmware update
Save the BBF on the MK3.5 USB stick, plug it into your printer and turn it on. The upgrade should now be offered.
MK4S MMU3 & MK3.5 @Home, MK4S MMU3 & XL 5 Head alongside EOS SLS @Work
Posted : 01/08/2024 3:29 pm
Payette
(@payette)
I have a printer cord input and a SD input.  No stick input (thumb drive I assume)
Posted : 01/08/2024 8:30 pm
Marcel Karger
(@marcel-karger)
Then you don't have MK3.5, check for MK3S(+) when downloading the firmware. Or another printer? Make sure you know what model you really have.
Posted : 01/08/2024 10:25 pm
Payette
(@payette)
First off thank you for your answers so far.
I do have a prusa Frankenstein that started life as a M the K3.  I may have only upgraded partially with the 3.5S+ hotend
I have only two ways in with this printer - the printer USB at the top of the Rambo - The SD slot
I went back and downloaded the firmware for only a 3.5 and once again, it is in a BBF format
My procedure to update the firmware is to download a .hex, then flash it
I'm stuck  - what's the procedure?
Joe Payette
Posted : 02/08/2024 10:50 am
Chip Wallace
(@chip-wallace)
This post was modified 9 months ago 2 times by Chip Wallace
Posted : 03/08/2024 10:08 pm
Payette
(@payette)
Thanks everyone.  I was downloading for the wrong printer
resolved!
Posted : 04/08/2024 11:43 am
