how does BBF work with MK3.5S+ for a firmware update
Payette
(@payette)
I am unable to find the hex file for the latest firmware update 6.0.4
I seem to only get to download a BBF and I am uncertain as to how that gets me a hex file that a can flash
Best Answer by Chip Wallace:
If you have and SD slot on the left of the screen, then you don't have a MK3.5.  The MK3.5 upgrade kit replaces the Rambo with the Buddy board, and a new screen that has a USB port on the right side.
It sounds like you just have a MK3 that you at least partially upgraded to a MK3s+.  The MK3.5 is a completely different machine.
I believe you need this firmware seen below.
Posted : 31/07/2024 6:37 pm
Marcel Karger
(@marcel-karger)
RE: how does BBF work with MK3.5S+ for a firmware update
Save the BBF on the MK3.5 USB stick, plug it into your printer and turn it on. The upgrade should now be offered.
CORE One MMU3, MK3.5 MMU3 and MK3.5S @Home, MK4S MMU3 & multiple XL 5 Head alongside multiple EOS SLS @Work
Posted : 01/08/2024 3:29 pm
Payette
(@payette)
I have a printer cord input and a SD input.  No stick input (thumb drive I assume)
Posted : 01/08/2024 8:30 pm
Marcel Karger
(@marcel-karger)
Then you don't have MK3.5, check for MK3S(+) when downloading the firmware. Or another printer? Make sure you know what model you really have.
Posted : 01/08/2024 10:25 pm
Payette
(@payette)
First off thank you for your answers so far.
I do have a prusa Frankenstein that started life as a M the K3.  I may have only upgraded partially with the 3.5S+ hotend
I have only two ways in with this printer - the printer USB at the top of the Rambo - The SD slot
I went back and downloaded the firmware for only a 3.5 and once again, it is in a BBF format
My procedure to update the firmware is to download a .hex, then flash it
I'm stuck  - what's the procedure?
Joe Payette
Posted : 02/08/2024 10:50 am
Chip Wallace
(@chip-wallace)
This post was modified 2 years ago 2 times by Chip Wallace
Posted : 03/08/2024 10:08 pm
Payette
(@payette)
Thanks everyone.  I was downloading for the wrong printer
resolved!
Posted : 04/08/2024 11:43 am
