        Error 23202 after upgrade
Hi all!
Getting hotend preheat error #23202,
I've checked the hotend and headbed thermistors and they change temperature when i use my hot air station on them.
Checking with a multimeter the heatbed shows 2.8 ohms and the hotend shows 14.1 ohms. Heatbed is a bit low but matches my other mk3.
All three fuses test good with the multimeter.
I see no voltage on either the hot end or heat bed when starting the heating tests, Guessing it's a bad board? Unless there are any other ideas.
I did start this upgrade a week ago and just finished tonight so may have missed something.
Thanks!
                            Posted : 25/03/2024 3:07 am
                    RE: Error 23202 after upgrade
I am having this exact same problem, have checked everything and it remains broken with no clear explanation.
                            Posted : 07/04/2024 12:42 pm
