Disable WiFi in settings?
Onno
 Onno
(@onno)
I initially enabled WiFi after getting my MK3.5 set up. However, I keep having reliability issues with file transfers, so I have hooked it up to Ethernet after acquiring a new switch. (BTW, only 100mbps?) Now I want to disable WiFi. I have tried to find the right setting, but somehow I can't turn off WiFi in the settings. The setting seems to be missing. The printer is still connected to the AP, even though I have the network setting set to use LAN/Ethernet. Is there a way to disable WiFi from the settings, or do I need to remove the module to disable WiFi access? It seems to interfere with hostname lookups.
Veröffentlicht : 27/09/2024 11:05 pm
