3.5 disable calibration not finished message
sh
 sh
(@sh-2)
I recently upgraded my oldest printer to an mk3.5. In calibration it is failing the heatbed heater check. I dispute the results though. I am able to manually set the bed temperature to 110 and it gets there no problem. The bed temperature looks correct according to a laser heat measurer. When I go ahead and just print it works correctly with the materials I have tried anyway. I have redone the printer bed wiring and cleaned all electrical contact surfaces. The underlying bed is in good condition. I have another mk3.5 I upgraded and also an mk4 which all pass their calibration tests and function great. I am confident that I upgraded this printer just like I upgraded my other 3. It is just on the older side and has many print hours under its belts. I have not seen any difference in print results between them and the printer that is not passing the calibration. I am on firmware 6.1.3+7898.
Whilst I would like it to pass the calibration test I am confident enough in it that I would be happy to just remove the warning. It is rather annoying to click through. Is there any way to do this?
This topic was modified před 2 years by sh
Napsal : 06/09/2024 4:18 pm
