String arts in threads not working well
Telles0808
(@telles0808)
I recently bought this app to make amazing string arts: https://cults3d.com/en/3d-model/gadget/app-to-create-string-art but the printer (mk3S+) is not anchoring the lines properly.
Where should I change to make it start and finish properly anchoring correctly inside the walls? It's like the printer is retracting and delaying to start the line, printing a line in the air without anchoring it first, also, it's not finishing the line properly too. Maybe the cuprite is the  rectration setting? Default setting, standard PLA.
Publié : 07/06/2024 2:07 am
Telles0808
(@telles0808)
Maybe the issue is with the slicer....
Ce message a été modifié il y a 2 years par Telles0808
Publié : 07/06/2024 2:28 am
RE: String arts in threads not working well
please provide a sample STL, for us to investigate.
my first thought is line thickness.   if the individual lines are smaller than the extrusion width set in slicer they will not print
can you adjust line thickness in the program?
if not, try changing 'extrusion width' in Prusa Slicer!
Maybe change the external perimeters value to 0.4mm
or  try changing the 'XY Size Compensation' value to artificially change line width
Publié : 07/06/2024 8:27 am
Telles0808
(@telles0808)
Here is the sample file. Thank you!
LAVINIA STRINGS
Publié : 07/06/2024 8:09 pm
Telles0808
(@telles0808)
Here is a example of what's happening, while the printer printed the strings starting and finishing on the air, the external perimeter wasn't ready, you can see it comming and the string on the air.
I'll try retraction 0 too. There is a option to config the anchoring extention? Something like penetration, or else.
Publié : 07/06/2024 8:19 pm
