Prusa Link
I was thinking of installing Prusa Link on my MK3S+. I have never used a Raspberry Pi before. When I look on the Prusa website it talks about using a Raspberry Pi 4, but the latest are the Pi 5. Can I use the latest Pi 5 instead? From what I have read there are some significant improvements in the 5 over the 4.
RE: Prusa Link
You posted this in the MK3.5 forum, so I'm guessing you have a MK3.5 and not just a standard MK3S+.
The MK3.5 has PrusaLink built-in and does not require a separate Raspberry Pi.
RE: Prusa Link
My bad, I have the i3MK3S+. But I did look again at the Prusa site and it seems I do need to add the Raspberry Pi Zero W. Would you agree? THanks for the reply in any case.
RE: Prusa Link
Check out this link.
Supported boards (GPIO connection on Einsy Rambo)
- Raspberry Pi Zero 2 W
- Raspberry Pi Zero W
Supported boards (USB connection)
- Raspberry Pi 4
- Raspberry Pi 3+
- Raspberry Pi 3
Unsupported boards
- Raspberry Pi Zero (without Wi-Fi) and older
- Raspberry Pi 2 and older
Hope this helps.
