MK3.5 Bondtech Extruder & Mosquito
Page 1 / 6
EvoDesigns
(@evodesigns)
Membre
Will the MK3.5 support the Mosquito & Bondtech Extruder with FW 5.2?
Thanks!
Publié : 06/02/2024 6:44 pm
vojthor
(@vojthor)
Membre
RE: MK3.5 Bondtech Extruder & Mosquito
Hey, wondering the same, have you found some answers elswhere?
Publié : 08/02/2024 9:42 am
Vostrikov
(@vostrikov)
Membre
Hi all,
 I’m wondering the same. It will be possible upgrade?
Publié : 18/02/2024 4:52 pm
Membre
Contact Bondtech and request it.  They will if there is enough interest.
Posted by: @vostrikov
Hi all,
Publié : 23/02/2024 2:34 am
Owens2303
(@owens2303)
I just ordered the MK3.5 kit for my MK3S+ which has the Bondtech Extruder and Mosquito fitted I was wondering the same should I convert my MK3S+ BACK to original hotend for the upgrade to work? would love to know before I start upgrading unit.
Publié : 23/02/2024 11:02 pm
Membre
I contacted Bondtech and to use their extruder, you will have to alter the control board and void your warrantee.   I am probably going to convert both of my printers back to the original extruder.  I will keep the hotted if I can.
Posted by: @owens2303
Publié : 23/02/2024 11:24 pm
1 personnes ont aimé
EvoDesigns
(@evodesigns)
Membre
Care to elaborate on what needs to be altered?
Publié : 23/02/2024 11:29 pm
Membre
I suspect, but cannot confirm, that you must remove the appendix from the control board to use the custom firmware.
Posted by: @evodesigns
Publié : 24/02/2024 2:35 am
EvoDesigns
(@evodesigns)
Membre
Given that the mini does not require specific firmware I doubt you'll need to break off the appendix of the new board. The bondtech extruders are essentially the same between the mini and MK3S, the only thing that the mini requires is for you to change the E-Steps and the direction of the extruder.
My only concern would be temperature control with the heater since the actual hotend is different. There isn't anything drastically different between the hotend carriages.
Prusa mentions that they are working on the Revo portion of the firmware, would that encompass all aftermarket hotends? It'd be a shame if I have to void warranty or be stuck on an E3D hotends.. they suck. Lol
Publié : 24/02/2024 2:54 am
John Weaver
(@john-weaver)
I've had the 3.5 upgrade running a few days now.  Bondtech LGX and Mosquito hotend with Diamondback nozzles.  After setting the e-steps to 800 I've had no issues whatsoever.  It's been a sweet machine so far.
I'm sure as I learn the new firmware I can tweak settings to take advantage of the Mosquito's higher flow but right now it's faster ( I wouldn't say twice as fast, a common print I run that used to take 1hr 23m now takes 46m) and the quality is maybe a bit better than before the upgrade.  I'm happy.
Publié : 24/02/2024 7:13 pm
Membre
The Bondtech extruder requires special firmware with the Mk3S+.  The Buddy may not support this and that is what Bonftech is indicating.
Ce message a été modifié il y a 2 years par cwbullet
Publié : 25/02/2024 2:07 am
Membre
The LGX and the standard Bondtech are different.
Posted by: @john-weaver
Publié : 25/02/2024 2:09 am
Membre
This is precisely what they said:
Yes we are but be aware a specific procedure that will void your warranty is necessary to install it.  We are still a couple of weeks away from release.  I'm forwarding your ticket to our colleague that is developing the firmware for more details, in case you have more questions. Thank you for using Bondtech.
Publié : 25/02/2024 2:14 am
EvoDesigns
(@evodesigns)
Membre
Leading with this initially would have been nice. I thought you were assuming.
Publié : 25/02/2024 2:22 am
John Weaver
(@john-weaver)
Bondtech says the LGX requires specific firmware but that apparently isn't the case if you set the e-steps properly.  I don't see anything in the OP that indicates a specific extruder 0ver another, so maybe this will encourage someone else with the LGX who may be on the fence.
Posted by: @cwbullet
Publié : 25/02/2024 2:15 pm
EvoDesigns
(@evodesigns)
Membre
The extruder that I have is a BMG 3:1 extruder, not the LGX.
Publié : 27/02/2024 4:03 am
Membre
I am upgrading two and will post my results.  I am hoping for success.  I will have to try to figure out the esteps for the 3:1.
Publié : 28/02/2024 11:47 am
EvoDesigns
(@evodesigns)
Membre
I'd start off with 415 since that's what's on the mini.
I need to finish printing the X Axis mounts in PCCF this week. I might be able to upgrade mine as well this weekend.
Publié : 28/02/2024 2:20 pm
ChrisG
(@chrisg)
Membre
You changed the profiles with the new e-step or is there a setting in the Buddy controls?
I have a few mk3's with Bondtech and Mosquito Magnum. It would be nice if I could convert the printers.
Publié : 01/03/2024 11:12 am
Membre
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles/has-anyone-upgraded-to-the-bondtech-extruder-and-what-has-been-your-print-quality-experience/
Look here: https://www.bondtech.se/en/product/prusa-i3-mk3s-extruder-upgrade/#tab-firmware
(Estep set to 830; adjusted Z_MAX_POS to 205; changed printer name).
For the Bondtech Upgrade, You need a new x-carriage. You can find all the files and information on the Bondtech side.
Posted by: @chrisg
Publié : 01/03/2024 11:42 am
Page 1 / 6
