How to set E-steps in Detail please.
Owens2303
(@owens2303)
I have the standard Prusa hotend installed on my MK3.5 with the BONDTECH extruder (Just upgrades from MK3s so all settings are standard nothing changed) how do I set the E-Steps to get my printer to feed correctly, Thanks (Novice)
Opublikowany : 09/07/2024 9:45 pm
John Weaver
(@john-weaver)
RE: How to set E-steps in Detail please.
Go to the hardware area on the LCD and long press, about three seconds or so.  You'll get a menu with the options to change e-steps.  Dial in what you want and click yes to save and reboot.
It's worth noting that there are different Bondtech extruders, with slightly different gear ratios, so you should go to their website, find your extruder model, and use Bondtech's recommendation for e-steps.  After all of that you should be fine, but it wouldn't hurt to run a calibration test to be sure.
Opublikowany : 10/07/2024 12:34 am
1 ludzie polubili
Owens2303
(@owens2303)
Thanks for the quick reply and information.
Opublikowany : 10/07/2024 2:09 am
robertfrost
(@robertfrost)
thanks
Opublikowany : 23/09/2024 11:14 am
