White smoke
Hello there
I have a problem with my printer. White smoke comes out from the hotend? Maybe. I change everything to sure. Hotend, nozzle, thermistor, cartridge heater, ptfe tube.
As result?! The same thing. White smoke and smell.
Any thoughts?!
Opublikowany : 18/05/2026 6:49 pm
RE: White smoke
White steam alone - humidity, need to dry filament.
But smell? Depends. There might be some issue with temperature sensing but moisture is a very common issue, because unintuitive in many ways e.g. when you open a sealed bag with a new spool, it is not necessarily dry.
Opublikowany : 18/05/2026 8:40 pm
RE: White smoke
would need more information. It could be what @mnentwig mentioned but I would also suggest reaching out to support so they can go over things with you to get to the bottom of it.
Shane (AKA FromPrusa)
Opublikowany : 19/05/2026 1:22 am
