        First Layer Calibration Error
I recently got a Prusa mini and after I assembled it, I went through all the automatic tests. Everything worked well except the first layer calibration test. The print head goes across the front of the printer and then pops up with an error saying that it failed. I have tried this many times now with the same result. Is there anything I am doing wrong or should check?
                            Opublikowany : 03/12/2023 1:41 am
