Suggested Buffer Alternatives/ MMU Feed equipment Changes???
moell
(@moell)
The Mk4s + MMU3 works beautifully and prints wonderfully.  But, there are usually some kind of exceptions:
1.  Loading the filament into and out of the original buffer is quite a headache, although doable with patience.
2.  Getting the filament loaded into the MMU3 is often a matter of fidgeting with the filament taper, sometimes with multiple attempts.
Napsal : 05/12/2024 4:06 pm
1 lidem se líbí
stevo1957
(@stevo1957)
RE: Suggested Buffer Alternatives/ MMU Feed equipment Changes???
Stock buffer works really well but the secret is, you need one of these to assist with loading.
https://www.printables.com/model/829946-mmu-loading-fork?lang=de
This is a game changer......it works perfectly and makes loading a breeze.
Also make sure the end of your filament has been straightened and use a tip sharpener to round the filament end for loading. (Something like this https://www.printables.com/model/154090-filament-sharpener-175mm).
Napsal : 05/12/2024 9:13 pm
2 lidem se líbí
stevo1957
(@stevo1957)
One of the above links was incorrect and I am not able to edit the post.
Try this one for the sharpener:
Napsal : 05/12/2024 10:13 pm
1 lidem se líbí
BID3D
(@bid3d)
MCS - Multi Color System for Prusa MMU3 by Real 3D Prints | Download free STL model | Printables.com
https://www.printables.com/model/555238-mcs-multi-color-system-for-prusa-mmu3
Works like a champ. 2000+ hours on mine, loads every time. Easy to build and use. Feeding filaments is quite easy.
Napsal : 05/12/2024 10:38 pm
1 lidem se líbí
spamplin
(@spamplin)
I finally settled on this combination all kept within the Prusa enclosure
https://www.printables.com/model/461663-spool-holder-1kg-or-2kg-for-original-prusa-enclosu
https://www.printables.com/model/845863-mmu3-mounting-kit-for-original-prusa-enclosure
The loading fork makes reloading filament very easy:
Works absolutely perfectly and is the most compact solution I have found to date.
Napsal : 06/12/2024 4:46 pm
1 lidem se líbí
LarGriff
(@largriff)
https://www.printables.com/model/1120406-the-shark-filament-buffer-and-drybox-system-v6
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Napsal : 28/01/2025 2:42 pm
I've tried a few alternative buffers, plus spent an insane amount of filament and time on trying to get a few "auto-rewinders" to work. Auto-reloaders plainly just didn't work in my hands reliably, they all ended up binding at some point. And I spent hours upon hours cleaning parts etc. Some of the alternative buffers looked interesting, especially the Shark linked to by LarGriff, but the way I load filament from a RepRack above one of my MK4S would have required some weird routing of the PTFE tubes.
I ended up not using any buffer at all. Or I call it, the "open air" buffer. You can see pictures here: https://www.printables.com/model/1130321
Sure, it ain't pretty, but so far it has worked fine, and I don't really see how the filament could possible get tangled given the closed topology and the amount of filament retracted.
Napsal : 28/01/2025 6:16 pm
1 lidem se líbí
LarGriff
(@largriff)
I abandoned the shark and went back to the original MMU3 buffer, fed from Sunlu S4 and S2 dryers.
The Prusa buffer may not be sexy, but it works.  Use of the loading tool mentioned above makes it fairly painless to load.
Napsal : 28/03/2025 2:59 pm
rex555
(@rex555)
I am in the same boat as @FoxRun3D in that I have spent too much time and money on filament trying rewinders and every other thing under the sun only to be frustrated by all of it. The one thing that really works well for me is https://www.printables.com/model/953614-mmu3-cassette-compatible-buffer-for-prusa-mk4-r4-c I still have some issues loading but with the cassettes easyish to access its not a massive pain to me. Its compact and just works during printing. I feed it from a Sunlu S4 set right behind the printer so the PTFE runs are short and straight and it works quite well.
Napsal : 09/07/2025 7:17 pm
Collin
(@collin)
I have been using this one for a while https://www.printables.com/model/30811-mmu-slot-buffer
I have my spools hanging on the wall with these https://www.printables.com/model/3094-wall-mount-spool-holder-with-bearings-customizable
the path works well to the buffer(also mounted to the wall), then up into MMU
The buffer is amazingly easy to use and the only issue I have had is with filaments wearing a slot in the slot covers over time, which obviously caused excess friction but they are easy enough to print
I have tried Joan's way, the BEST way but I didn't have the luck I hoped with it, I don't remember what didn't work but I want to try it again.  I suspect it was the 2mm tubing I was using at the time.  When I move my setup to a new room next year I plan to try again with my 2.5mm tubing I use now.
Napsal : 11/12/2025 4:24 pm
sandrainNZ
(@sandrainnz)
@ FoxRun#3D - Hi, how is this solution working for you, one year on?? I just bought the MMU and it seems to need an insane amount of space, so your idea is really appealing. Also a way to get rid of a lot of that PTFE tubing. If you found it OK, I will do something similar
Thanks
Sandra
This post was modified před 1 month by sandrainNZ
Napsal : 27/03/2026 8:40 am
