Mmu3/2 setups
Strona 1 / 2
Hello
(@hello)
Mmu3/2 setups
Hi I'd love to see your guys setups I'm trying to get my spools plus buffer to fit and organized
Opublikowany : 31/08/2023 9:58 am
Milstream
(@milstream)
RE: Mmu3/2 setups
This is my MMU2 setup, hoping to be able to adapt to MMU3 when the upgrade arrives.
Opublikowany : 08/09/2023 9:40 am
Runs error free for over 5 years now...
wbr,
Karl
Opublikowany : 08/09/2023 1:09 pm
2 ludzie polubili
Tom De Winter
(@tom-de-winter)
RE: Mmu3/2 setups
Are files available for this setup?
Opublikowany : 08/09/2023 1:56 pm
RE: Mmu3/2 setups
Yes, Step Data. I provide my data without any guarantee, warranty. Building instructions and parts list is not included.
Sent you a message to the link.
wbr,
Karl
Opublikowany : 08/09/2023 5:31 pm
1 ludzie polubili
Hello
(@hello)
RE: Mmu3/2 setups
Posted by: @karl-herbert
wbr,
Karl
Jee that's a fancy setup whats the screen running
Opublikowany : 08/09/2023 6:27 pm
ad.lamy
(@ad-lamy)
RE: Mmu3/2 setups
My MK4/MMU3 compact setup, works flawlessly.
MK4/MMU3 - VORON 2.4 350 Stealthburner
Opublikowany : 05/05/2024 5:27 am
BigToeDaddyO
(@bigtoedaddyo)
Auto-Rewind, baby!
MK3S+, MMU3, PrusaBox, Spool Tank and a bunch of other stuff…
Btw - after calibration, it just works!
This post was modified 2 years temu by BigToeDaddyO
Opublikowany : 05/05/2024 5:53 am
ManelTo
(@manelto)
RE: Mmu3/2 setups
I see attractive designs. Waiting for the next ones.
Sorry for my poor English. I try to do my best.
Opublikowany : 06/05/2024 9:09 am
Rainer
(@rainer-2)
RE: Mmu3/2 setups
My setup without filament buffer. So far it works without any problems.
Opublikowany : 06/05/2024 9:26 am
ManelTo
(@manelto)
RE: Mmu3/2 setups
without buffer? Not a problem?
Posted by: @rainer-2
Opublikowany : 06/05/2024 9:13 pm
Rainer
(@rainer-2)
RE: Mmu3/2 setups
So far it has worked without any problems.  I have inserts in the boxes to prevent tangling.
Opublikowany : 06/05/2024 9:53 pm
1 ludzie polubili
ad.lamy
(@ad-lamy)
RE: Mmu3/2 setups
Clever, the simplest ideas are often the best.
I never used the Prusa buffer before, but I told myself that I would still test it one day, and finally it works perfectly well.
Opublikowany : 07/05/2024 6:48 am
Eric T
(@eric-t)
RE: Mmu3/2 setups
Here's my setup:
MK3.5/E3DRevo/MMU3
Opublikowany : 08/05/2024 6:00 pm
3 ludzie polubili
BigToeDaddyO
(@bigtoedaddyo)
Really like this set-up!
Clean, simple, compact, accessible.
I really like how you can see everything!  One of the tricky parts of making things compact is retaining the ability to identify and debug where the fail happens and then being able to access whatever is needed to rectify.  Your set-up makes that easy!
Great Job!
P.S.  And Thank you for the links!  We may (will) replicate on our next (3rd) printer!  Please either post or PM any build tips, tricks, ideas, revisions or “things I will do next time”…
Opublikowany : 10/05/2024 1:26 pm
PFA
 PFA
(@pfa)
Spool setup from shelf brackets and PVC pipe
I just got the MMU3 and almost have it all assembled. Long ago, I had a lower end 3D printer and used the attached image to manage my spools. It fits two as pictured. Low tech, easy. I am contemplating just doing a longer pole and putting all five spools on this same setup. What do you all experienced folks think? Will that work do you think? Or will I need to provide some sort of separation between spools? Do you think the spools will want to interfere with each other without it?
Thanks.
This post was modified 1 year temu by PFA
Opublikowany : 20/06/2024 7:37 pm
RE: Mmu3/2 setups
I have used a single broom handle with 5 spools on it... spaced about 3 feet (1 metre) away from the printer.
I bring the filament from the under side of the spool, to the feed in PTFE tubes and into the MMU3.
Load as normal, then in use, the backfed filament coils up in Mid air as an 'air buffer',
with the filament coming under the spool to the printer, gravity prevents the filament transfering over onto adjacent spools
Opublikowany : 21/06/2024 12:31 am
PFA
 PFA
(@pfa)
RE: Mmu3/2 setups
Great thanks. I'll go with the long pole then.
So, are you suggesting not to use the cassette buffer? I was planning to still use it, but just maybe install on the wall or something like some of the other folks pictured here.
Opublikowany : 21/06/2024 12:37 am
I am not suggesting anything, just saying I didn't use the cassette buffer.  Lol...
when Prusa had their Mk4 MMU3 at SMRRF Oxford, they didn't use the buffer either...
If you stray from the straight and narrow, you may have to make adjustments!...
I don't have space for cassette buffers and discrete spool holders
Opublikowany : 21/06/2024 12:45 am
PFA
 PFA
(@pfa)
RE: Mmu3/2 setups
Roger that. Thank you.
Opublikowany : 21/06/2024 12:57 am
Strona 1 / 2
