Mk4s Standard vs MMU3 Speed (One Colour)
Hi All
Apologies in advance; some of this topic has been discussed and there have been some really insightful answers but I'm just after a few more user thoughts.
Given that the recommendation is to use a Standard Nozzle rathe than the High Flow Nozzle when using the MMU3, does that mean if you print in a single colour it will be a lot slower, unless you change the nozzle?
Is it better to bypass the MMU3 and change back to the High Flow Nozzle?
I ask because while I like the idea of the MMU3 (from usage and technical fun perspectives) it's likely that I will still be printing single colour most of the time, so I'm trying to work out what the best set up is. I assume I'm not the only one in that boat?
Ssendam
RE: Mk4s Standard vs MMU3 Speed (One Colour)
The recomendation to use the standard nozzel is just if you print mulitple colours, because of the prurge process. If you use only one color you can use the MMU without any problem.
Thanks, makes more sense now. So I can leave the MMU3 all set up, for 1 colour and the High Flow Nozzle, and get the 'normal speed, then when I want to do Multi Colour just swap out the nozzle to avoid and issues.
