0.25 nozzle with MMU3 + MK4?
Rui Guerra
(@rui-guerra-2)
Hi all,
I'm aware that when the MMU3 appeared the only nozzle that could be used with it was the 0.4.
But now, I wonder if it is already approved by Prusa that we can use other nozzles, specially the 0.25, for more detailed text in prints?
Thanks!
Opublikowany : 01/04/2025 3:38 pm
LarGriff
(@largriff)
RE: 0.25 nozzle with MMU3 + MK4?
You can select 0.25 nozzle in settings-printer-extruder1.  All extruders of course use the same nozzle size.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Opublikowany : 19/04/2025 6:24 am
Rui Guerra
(@rui-guerra-2)
Posted by: @largriff
So that means no more nozzle size restrictions with MMU3? Is it now simple and trouble-free like using another nozzle without the MMU3 installed or are there any cons that I should be aware of?
I remember reading not long ago that one had to add/change some code to be able to use other nozzle dimensions with the MMU3 and some times there was some problems at printing time…
Thanks
Opublikowany : 19/04/2025 7:07 am
SCMemphis
(@scmemphis)
I wondering the same thing. I just ordered some .25mm nozzles to use with my MMU3 to try and print some better miniatures and wanted to make sure it will not be a uphill battle every time I try to print.
Opublikowany : 07/09/2025 1:53 pm
Rui Guerra
(@rui-guerra-2)
It looks like no one else has a clear answer to this (?)
Opublikowany : 15/09/2025 3:58 pm
