Printing seperate objects in difference colors.
ChiTownGuy
(@chitownguy)
Let's say I have 6 objects on the plate, how do I print each of in a different color without a wipe tower.
Since each object is a single color they would need to print sequentially with a very small wipe tower only when moving on to the next object.
This is done to save time by not having to print each one with a separate slicing pass.
See the attached file for an example (thought the objects do not all need to be the same, they are in this case)
Publié : 12/06/2024 2:03 am
Eef
 Eef
(@eef)
RE: Printing seperate objects in difference colors.
See this thread: https://forum.prusa3d.com/forum/prusaslicer/color-change-with-sequential-printing/
under PRINTER SETTINGS > CUSTOM GCODE there is a "BETWEEN OBJECTS GCODE box where you can add custom gcode..
Publié : 12/06/2024 6:14 am
ChiTownGuy
(@chitownguy)
Unfortunately that will only work for a single color change between two objects since the same gcode will appear in between each object.
Posted by: @eef
Publié : 13/06/2024 12:32 am
Eef
 Eef
(@eef)
OK. understand. There seems to be another route: https://github.com/Kwekker/PrusaSlicer-gcode-object-mover
Publié : 13/06/2024 5:52 am
