Print Woodfill on MMU3
Has anyone used Colorfab woodfill on an MMU3? I have some of this filament and want to print an object using only this filament (no changes) but the MMU does not have a profile for this. Can I somehow import the profile over from the single extruder ones?
Thanks.
Veröffentlicht : 19/01/2025 10:53 pm
RE: Print Woodfill on MMU3
Just turn off the MMU and run your printer in single filament mode, it's in settings somewhere to turn off MMU. You will need to feed the filament directly into the PTFE tube attached to the print head but it should then work like whatever printer you have and you can use the regular presets for single extruder.
Veröffentlicht : 09/07/2025 8:39 pm
