New to MMU3 - Color Bleed
CMR
 CMR
(@cmr)
I am new to using a MMU3 and I need help with my PrusaSlicer settings. I have tried twice to print a model that has a outer lattice (Inland Tough PLA Metallic Bronze) surrounding an inner container (Inland Silk PLA Silver), but as you can see, before I got very far into both attempts, the bronze filament was overpowering the silver. What am I doing wrong/should be doing/need to change in my configuration?
Thank you!!
Postato : 21/07/2024 12:01 am
MysticGringo
(@mysticgringo)
RE: New to MMU3 - Color Bleed
Looks like you need more purging between filaments. There's a Purge Volume button just below the support enforcers selection on the plater screen. Also, you can set individual filaments to have more purge in the filaments in the "purge volume multiplier".
Postato : 23/07/2024 12:09 pm
Lynn
 Lynn
(@lynn)
MysticGringo is correct, extra purging of the lighter color is the only way to eliminate the bleed through.
Thanks MysticGringo, I hadn't noticed the purge volume multiplier setting.  I learned a new thing.
Postato : 23/07/2024 5:19 pm
Patriot50
(@patriot50)
Utenti
I am printing 3 color keychains with a dark red, dark blue, and silver.  The red hangs out in the extruder and bleeds into the silver badly.  I ended up creating 3 different filament settings and attaching each to the extruder for that color.  The key setting is Minimal purge on wipe tower in mm^3.   Red doesn't need much stays at default 35 mm^3, blue set to 90mm^3, and silver  set to 110mm^3.
Postato : 01/01/2026 5:37 pm
1 persone hanno apprezzato
