More than 5 Filaments with MMU3?
SierraGolf
(@sierragolf)
Hey there,
i want to print a custom ID Badge holder with an special logo in the first layers. I did it a several times before with 4 and 5 Colors, easy mmu print.
But with my new idea i ran into a problem... the finished model uses 6 Colors and im curiouse if there is any trick to make this print. i added a Screenshot for that i added a 6th toolhead, just for visualization.
Before you ask, yes, i could print this using SingleHeadMultiMaterial but i wanted to ask if there is a nice little hack for the mmu3 solution,
thanks for your help 😉
This topic was modified před 5 months by SierraGolf
Napsal : 10/12/2025 11:42 am
LarGriff
(@largriff)
RE: More than 5 Filaments with MMU3?
I remember seeing an example of this somewhere, maybe in the mmu documentation.
5 colors on the mmu with a sixth color changed manually by inserting a pause in the gcode.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Napsal : 11/12/2025 2:19 pm
1 lidem se líbí
AVDS-1790
(@avds-1790)
Posted by: @largriff
This is the same thing I was thinking.  I don't remember seeing anything in the documentation, but I'd like to know if you find it!
"I can change, if I have to, I guess."-Red Green Prusa Core One + MMU3
Napsal : 11/03/2026 6:30 pm
Same Old Shane
(@same-old-shane)
Member Admin
its "kind of" like this, but there is a extra step with a MMU3 (or in the XL) where you would click on that little plus sign and it will give you the option to select the extruder and then the option to do a color change.
https://help.prusa3d.com/article/color-change_1687
Shane (AKA FromPrusa)
Napsal : 12/03/2026 3:56 am
