MMU3 Layer height restrictions?
Stefan
(@stefan-17)
Utenti
Hi all,
I am doing my first walking attempts with the MMU3.
Plan is to print a ring (25 x 7mm) with engraved text and two alternating colors, such as Galaxy Black for 2 millimeters, Glow in the Dark for 3 millimeters and another Galaxy Black for 2 millimeters. I strive for the lowest possible layer height to achieve maximum smooth surface.
Somehow, I struggle setting the layer height below 0,15mm- is that works as designed or am I just doing it wrong?
Any suggestions welcome!
Thanks! 🙂
Postato : 23/05/2024 9:50 am
RE: MMU3 Layer height restrictions?
As your layer height gets smaller, your purge block needs to get bigger.
There are a small number of profiles in the list. But you can manually adjust them in print settings, layers and peri
You may need to be in advanced mode...
Postato : 23/05/2024 12:49 pm
Stefan
(@stefan-17)
Utenti
Hey Joan,
thanks for getting back to me! I had to unlock the factory settings to override the preset 0,15mm.
Hope that was my only mistake.
Cheers!
Postato : 23/05/2024 1:12 pm
Good luck, happy printing
Joan
Postato : 23/05/2024 2:09 pm
Stefan
(@stefan-17)
Utenti
Worked like charm... thanks again!
Postato : 23/05/2024 2:27 pm
Excellent!
Joan
Postato : 23/05/2024 5:44 pm
