MMU3/extruder makes odd clicking sounds and fails to load the filament in one slot
Sean Kane
(@sean-kane)
I have noticed that sometimes, when I try to load a new filament into a slot in the MMU3, it starts clicking, and the filament (typically PETG) won't load. I usually have to pull it out and cut it at least a few times and just try again to eventually get it to work, but I don't understand exactly what is happening despite having built this MK4 and MMU3 from the kits.
Video of the problem occurring (with audio)
The filament can be passed all the way through Bowden tubes just fine, right up to the extruder. However, when I pull the filament back out, I notice it has some pretty deep grooves. I suspect that the little "gears" that pull the filament forward aren't working in this case, and maybe that is causing the clicking (but I don't believe this is the root issue). Any thoughts or help understanding what is going on would be greatly appreciated.
Thanks.
Sean
Veröffentlicht : 14/08/2024 1:32 pm
JP Guitars
(@jp-guitars)
I had a similar problem and eventually figured out that it was the filament which had got hard and was holding the curve it picked up whilst on the reel. Then when it tried to feed through to the bowden tube it missed and hit the surround, it also occasionally missed by so much that the filament came out the side. This also got worse the further into the reel I got. Trying to sort this out I also ended up getting some broken bits of filament stuck in various places in the MMU which were a pain to remove.
As I wanted to get the job finished I swapped out the reel and picked out the broken bits from the MMU and that fixed it. I suspect the hard, brittle filament was caused by it being damp but as I've not need that colour since I've not bothered drying it and retrying but I will some time.
Veröffentlicht : 14/08/2024 2:23 pm
JP Guitars
(@jp-guitars)
RE: MMU3/extruder makes odd clicking sounds and fails to load the filament in one slot
OK, had the same thing a couple of days ago. Stuck the filament in the dryer overnight and now it is switching in and out on the MMU just fine
Veröffentlicht : 17/08/2024 10:24 am
Jay
 Jay
(@jay-20)
I'm having essentially the same issue except that no amount of snipping, sharpening, and drying will get the filament to load via the Preload to MMU option. If I try to load into slot 1 there is an awful sound as the idler assembly turns and I can't get the filament to catch at all. For some of the others I can get the filament in and it will grab enough that I can't manually pull it back but it won't get pulled through. Sometimes I get clicking and vibration as seen in the video Sean Kane linked. I have opened the MMU idler door multiple times and cannot see any obvious obstruction or damage. Any suggestions? I'd liked to fix this with as little disassembling of the MMU as possible.
Veröffentlicht : 04/12/2025 3:58 pm
