MMU3 and printing ABS or PC: is it possible??
Harlok67
(@harlok67)
Hi everyone, I have the MK4 and soon it will become the MK4S with MMU3 latest firmware version.
I need to print some parts in ABS or PC but in the choice of filaments ABS or PC does not appear. Only PLA or PETG.
Best Answer by vhubbard:
For one color, I slice it as standard MK4 without MMU3, then when it comes time to run, the printer will show the filaments 1-5 and what it thinks they are.  I assign the ASA or PC to the correct filament number, and then select the filament to run.
This discussion has details on selecting the filament when using a standard file with MMU3.
Respondido : 16/08/2024 6:58 pm
vhubbard
(@vhubbard)
RE: MMU3 and printing ABS or PC: is it possible??
Respondido : 17/08/2024 3:13 pm
Harlok67
(@harlok67)
RISPONDI: MMU3 and printing ABS or PC: is it possible??
 🤔   I hadn't thought of this solution..I want to try...
Thanks!
Respondido : 18/08/2024 8:17 am
Harlok67
(@harlok67)
I tried to do as you suggested...It works. You can see that the profiles are not optimized but for simple ABS parts, a single color are ok.
Thanks for the suggestion
Respondido : 20/08/2024 3:43 pm
