MMU Filament Print Order
Mezzauk
(@mezzauk)
Hi, I have experimenting with MMU and wondered if anyone knew before i make a set up change. I have petg in the following order 1.Blk, 2.Org, 3.Grey, 4.White and 5.Red. When printing the MK4 Logo the various colours print in filament order. I wondered if i swap Black and Red and print the inlays first then the outer black segments will this give a more precise print? It looks like there is a github ticket for printing in any specific order but wondered if anyone had any experience with this? Many thanks if you spend time to respond.
Veröffentlicht : 30/01/2024 5:48 pm
S'Mike
(@smike)
RE: MMU Filament Print Order
It does print in right order. So you have to set it up with your first color in slot 1. No way around that.
I print "signs", and I always print the text color as slot # 1, because the text is crisper that way. Make sure your text color is high color density BTW, otherwise you get color "bleed" around the edges. It would be nice if you could select it, but I don't think it is a necessary feature.
Veröffentlicht : 14/07/2024 1:32 am
