Time to next change?
I see one of the times the new microcode cycles through displaying is "time to next change", but it always says N/A. Does it not apply to MMU3 changes, or is it simply not implemented yet?
Postato : 01/05/2024 2:54 am
RE: Time to next change?
Yes I wondered that too for a while.
...until I did a 6 colour print and so needed to do a physical swap during the print. So that's when I realised it was the time until you need to do this intervention.
Helpful, but not too clear until you know. Probably should not been cycled through if set to n/a to avoid confusion
Postato : 01/05/2024 8:33 pm
1 persone hanno apprezzato
