Resume print z offset changed
Cindy L
(@cindy-l)
Mitglied
Today I had a my Mk4/MMU3 ,5.5 hr print, stop at 4 hrs with a finda error. I noticed the filament currently loaded had a tangle in the spool. I was able to untangle it but could not get the print to resume as the filament seemed to be stuck. Nor would it unload. I was able to unload it manually and then planned to reload after double-checking the spool again. I could find no option to “preload” in the mid-print “tune” menu and could not get it to go into the PTFE slot on the MMU3. So, I undid the tension screws, opened the idler, and was able to manually direct the filament into the MMU3. I closed the idler, adjusted the tension screws, and hit “continue” in the load filament screen. It worked! I was able to resume the print….but quickly noticed my z-offset was much to high and it was printing in the air. I could find no way mid-print to quickly adjust it. And that was the end of it.
Maybe I am missing something…but trouble-shooting issues like this, mid-print? It seems there are few software/interface options for resuming the print successfully. Or adjusting the offset if it needs to be corrected.
Dieses Thema wurde geändert Vor 2 years von Cindy L
Veröffentlicht : 24/07/2024 8:33 pm
dr_stefan_krank
(@dr_stefan_krank)
RE: Resume print z offset changed
Could it be, that your printer detected the jam to late and was printing a few layers without filament? Happened to me, at least.
Veröffentlicht : 31/07/2024 4:40 pm
