Need to change the Bowden tube length in firmware
[Solved] Need to change the Bowden tube length in firmware
RedTar
(@redtar-2)
Ive recently made a few changes to my MK4S-MMU3 set up and deleted the Buffer chamber portion of the set up and added a new dry box that uses auto rewinding spool holder in the dry box, negating the need for a buffer chamber (Soooo much better!).  This setup worked very good and was repeatable and reliable but loading it was a bit of a pain and cumber sum.
I wanted the MMU3 to be on top of the dry box for ease of loading and to clean the setup up a bit and make it more organized.  So I soldered a length wire to the MMU3 control wire and added a new longer Bowden tube to the set up. see picture below.  clean, easier to load but.......
Now the MMU3 will not load the filament far enough to reach the extruder. everything else works just fine on the MMU3.  apparently there a hard coded length of 340 mm that the MMU3 will only go (because the buffer chamber would over flow, but i no longer have a buffer).  Ive looked everywhere I can think of to make the load length longer in the Prusa slicer but I have had no luck with any of the changes, nothing makes the MMU3 load longer than 340 mm.
Ive tried changing the Start up G code using M708 A0x0b x 550 and Ive tried M708 A0x22 x550 but it doesn't change anything either.  Am i skipping something when i change the start up g code? I'm saving the G code changes, re-slicing the part and loading it on the USB drive and then loading it into the printer.
I don't use Octoprint or any other software, Im only using the Prusa slicer software to make changes.
Can any one help me work this out, I really like the set up as it is and want to keep it this way.
Ive asked the factory for help and they state that this is an unsupported change and to look here in there Blog.
Napsal : 19/03/2025 2:07 pm
LarGriff
(@largriff)
The printer is VERY picky about proper case and spacing.  Instead of M708 A0x22 x550 try M708 A0x22 X550.
I hope this helps, but keep in mind that this will also have the effect of increasing the amount of material retracted into the buffer (or rewinder).  Are you prepared to deal with that much more buffering?
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Napsal : 22/03/2025 6:40 am
2 lidem se líbí
LarGriff
(@largriff)
RE: Need to change the Bowden tube length in firmware
P.S.  The Bowden Length register (A0x22) is memory Persistent, so you only need to write to it once.  After that, you don’t have to add the gcode any more.
Napsal : 22/03/2025 6:49 am
2 lidem se líbí
RedTar
(@redtar-2)
But how do you change that value in the MMU and what do you use to change it?
Napsal : 22/03/2025 3:07 pm
RedTar
(@redtar-2)
Thanks for the reply!
All the research I've done shows a small case x IN front of the final number that's why I used a small case x. ill try a upper case x but I'm still not sure how to send it to the mmu.  I've been putting it in the start up g code file and then re-slicing the part and loading it on to my usb drive, then i load that usb drive into the printer. but nothing seems to happen or change.  what do I need to do the send that change to the mmu?
This post was modified před 1 year by RedTar
Napsal : 22/03/2025 3:14 pm
3Delight
(@3delight)
Moderátor Moderator
You can add the following in to the start of your GCode file just the once:
M708 A0x22 X####
where #### is the length in mm.  There is information here: https://help.prusa3d.com/article/prusa-firmware-specific-g-code-commands_112173
Or you can send the command via octoprint or Pronterface
Napsal : 22/03/2025 3:19 pm
1 lidem se líbí
LarGriff
(@largriff)
You were doing the right thing, sending it in your startup gcode.  It just wasn’t successful because of the syntax.
Napsal : 22/03/2025 7:00 pm
1 lidem se líbí
LarGriff
(@largriff)
Or you can simply create a file with one line.
M708 A0x22 X450
Make sure to put a Return at the end of the line.  Save it as MMU_Change.gcode or whatever.
Print that file.  Done.
Napsal : 22/03/2025 7:12 pm
1 lidem se líbí
RedTar
(@redtar-2)
That was it!! good grief all this head ache because I used a small x instead of a capitol X, I'm so embarrassed.
Thanks you guys for all your help!
Napsal : 23/03/2025 5:02 am
1 lidem se líbí
Voxel3D_NL
(@voxel3d_nl)
Hi,,
Getting back on this, I tried to do the exact same, and I can set it correctly (If I send M707 A0x22 it reports "384" which is hexadecimal for my 900mm bowden length. but, when loading it does about 300mm quickly and then still continues slowly??
Any tips?
Napsal : 09/04/2025 8:15 am
miroslav.h4
(@miroslav-h4)
Your 384 returned by the M707 A0x22 command is really your about 300mm (exactly 384mm) of fast charging, and not any hexadecimal 900mm! You have to enter the 900mm value there in decimal, i.e. M708 A0x22 X900. The length must be between 341 and 1000mm, otherwise it will not be saved.
Napsal : 09/04/2025 9:25 am
OldGuyAdventure
(@oldguyadventure)
Actually, if you flash the firmware you will overwrite the memory blocks where the length is stored also. So always need to keep that in mind. For me I keep the length statement in my gcode as a precaution should I change out my firmware. I just notate the entry as what it is.  Also, best to back up critical settings because anything you can not recover in a week is worth backing up. If you are basing your business on digital files backups are critical.
Napsal : 10/07/2025 11:52 am
Raph_38
(@raph_38)
Hello, Happy New Year,
I am facing the same problem. I have a Prusa MK3,5S, Prusa Enclosure, and a box for my spools (with auto rewind spool holder, so built-in buffer). If I understand correctly, to change the length of the PTFE tube, I need to create a gcode file on the USB key with the value M708 A0x22 X450 (the length ptfe ). To execute it, start a print job by selecting this file, or use Pronterface. Will the setting be saved directly to the MMU's EEPROM, or will it need to be executed before each print job ? Then, to return to the default value if necessary, is a reset sufficient ?
Thank you for help
Napsal : 06/01/2026 1:33 pm
LarGriff
(@largriff)
@raph_38 the setting will be saved to the MMU EEPROM.  The gcode file only needs to be “printed” once.  The two ways to reset the length are to make, and print, a new gcode file, or to reflash the MMU.
Napsal : 18/01/2026 3:30 pm
