MMU3 Spool Join
chandler
(@chandler-2)
MMU3 Spool Join
I am looking for the spool join function when sending a Job via Prusa Connect to my mk4s/MMU3. I tried to put the job to the print queue to activate it on the printer display to have the option of setting up spool join. The job contains only one material. Unfortunatly I do not get the menu for setting it up. Whats is wrong? Is it neccessary to enable it anywhere else? I cannot find anything in the settings menu for it. I use the most actual firmware 6.1.4.
Is there also a way to set up spool join also in the Prusa Slicer?
Respondido : 30/12/2024 1:19 pm
Plugs
(@plugs-2)
Miembro
RE: MMU3 Spool Join
The only way I achieve spool join is via the Print Menu on the MK4 . As documeneted for XL here https://help.prusa3d.com/article/tools-mapping-xl_668277. That said I also looked for Prusa Slicer Spool  Join and could not find anything. My problem is it still doesnt work and it does not unload the old filament before loading the next filament.
Respondido : 31/05/2025 3:49 pm
