RE: MMU3 functions not visible in the MK3s menu
I found the problem.
If the finda is enabled because it is not correct set the homing procedure of the mmu is not started.
The Load filament in the menu is not showed.
Chris
Opublikowany : 18/03/2024 6:53 pm
