MMU3 3.0.4 error but printing
Mugatuu
(@mugatuu)
Just loaded up the new Core One Firmware and flashed the MMU3. Started  a 2 color test print.
It pulled in tool one fine, then popped up the error: FSENSOR FIL. STUCK, but it's printing fine?
It's currently printing the first few layers with tool 1 like it should. Error displayed in Pursa connect and on the screen.
Not sure what's gonna happen when tries to swap to tool 4. Will report back.
Opublikowany : 25/03/2026 11:51 pm
Mugatuu
(@mugatuu)
RE: MMU3 3.0.4 error but printing
It printed fine until the tool swap.  Went over to the wipe tower and just stopped.  I couldn't use the local LCD to "retry" or send commands via prusa connect.  Had to hard reset.
Upon restart, I was able to run the unload operation just via the MMU menu.
Opublikowany : 26/03/2026 12:06 am
Mugatuu
(@mugatuu)
Support had me reset the MMU3 with this procedure:
please run a hard reset to the mmu3 unit following this guide, seems to be a glitch in the firmware version: https://help.prusa3d.com/article/factory-reset-mmu_510075
Seems to have addressed it.
Opublikowany : 26/03/2026 12:41 am
