mmu with newer firmware than printer
Sumta
(@sumta)
does anyone know if there is a major issue with running newer firmware on a older printer.
have a mk3s+ with the newest firmware for it
mmu firmware current is 6.4.0 (3.0.3) , but mmu mk3s+ is 3.14.1
Best Answer by stevo1957:
There is only one firmware file for the MMU3 - version 3.0.3. It doesn't matter which printer firmware file you grab it from so just unzip the version 6.4.0 file and flash the 3.0.3 firmware file to the MMU3.
Opublikowany : 11/02/2026 12:11 am
stevo1957
(@stevo1957)
RE: mmu with newer firmware than printer
Opublikowany : 11/02/2026 8:29 pm
stevo1957
(@stevo1957)
For some reason, I can't edit my post. Don't put any new firmware on your Mk3S+ as you are on the latest version. 6.4.0 is not compatible with the Mk3S+.
Opublikowany : 11/02/2026 8:33 pm
Sumta
(@sumta)
Good to know the mmu3 firmware is still relevant , regardless of printer type.
Ty!
Opublikowany : 11/02/2026 8:35 pm
