mmu not seen on prusa connect
Sumta
(@sumta)
hello folks.
been trying to get a consistent solution to my mmu3 problem.
i have a mk3s+ with mmu3 and pi zero
most times prusa connect will just see it as a mk3s+
if i power cycle it repeatedly it might show the mmu 20-30% of the time but stay busy until i hit the reset button, than odds are, it will go to idle without mmu.
it is very very rare that it will show mk3s+ with mmu correctly.
Firmware3.14.1-8237
PrusaLink0.8.1
Best Answer by Sumta:
i have found a set of steps as a work around for now.
but  a long term fix would be appreceated if someone finds one.
with the printer on and not showing mmu in prusa connect.
step 1: turn mmu off in printer settings
step 2:turn printer off and wait 10~ seconds
step 3: turn on and wait for prusalink to finish loading (prusa connect should show your (my mk3s+) as idle)
step 4: wait 60~ seconds
step 5: turn mmu in settings on and hopefully mmu populates in prusa connect.
works for me for now, i only have 2 units (mk3s+ with mmu3's)  , but a larger farm would find this reset process a problem XD.
Opublikowany : 01/12/2025 12:08 pm
Joe Grubbs
(@joe-grubbs)
RE: mmu not seen on prusa connect
I have the same issue with my Core One and the PRUSA Connect, connect does not recognize that there is a mmu3.
CoreOne Firmware 6.4.0+11974
Opublikowany : 06/12/2025 1:56 am
Sumta
(@sumta)
Opublikowany : 17/01/2026 8:10 pm
1 ludzie polubili
