MK4 with MMU3 filament sensing issue
Mike
 Mike
(@mike-35)
After trying twice to resolve the issue of filament sensing after the  addition of an MMU3  ( with the following from a chat with help desk ,With MMU both Filament sensor should work together, the one within the extruder and the FINDA sensor in the MMU)
My unit is a MK4 with the addition of the MMU3, and recent upgrade to the 4S. When adding the MMU3, instructions said to remove the ball, spring and magnet plastic piece that works with the hall sensor, thought the sensor in the MMU3 took over the job of sensing filament.  Can't finish the calibration as the unit doesn't sense filament. cant find the plastic piece that holds the spring, ball and magnet, or i would reinstall it. Have the latest firmware, and tried resetting the unit to factory spec, still doesn't sense filament.
Am I missing a step ( or 2)  ?
Napsal : 26/11/2024 7:53 pm
Volker
(@volker)
RE: MK4 with MMU3 filament sensing issue
With the parts for the MMU3 there should be some parts to modify the MK4 nextruder sensor. Just removing the Sensor with the ball is not enough. You need to install a modified sensor which is coupled to the idler door. Follow following step:
9A. MK4/S, MK3.9/S Nextruder Mod | Prusa Knowledge Base
Napsal : 27/11/2024 5:57 am
Mike
 Mike
(@mike-35)
besides the MM U3 addition to the MK4, Ive upgraded to the MK4S, with this upgrade the new idler nut doesn't have any magnets, not sure how the filament sensor works without a magnet.
Thanks for the assist
This post was modified před 9 months by Mike
Napsal : 27/11/2024 6:27 pm
I suspect you need to re attach the old idler nut and main plate from the MMU version of the nextruder
did you change the idler parts as well. if so, you probably need the original Mk4  mmu parts
Napsal : 27/11/2024 8:27 pm
fester225
(@fester225)
I'm having the same problem. The manual said to remove the old filament sensor, it wouldn't be needed. Slicer has been upgraded, MMU3 has been flashed. When I go to Calibration & Tests, I'm told there is filament in the printer when there is not. This happens before I can get to Gears Calibration.
How do I clear this problem?
Napsal : 28/04/2025 8:20 pm
LarGriff
(@largriff)
I think you need this part that has the magnet?
https://help.prusa3d.com/guide/9a-mk4-s-mk3-9-s-nextruder-mod_683106#686804
MK4S/MMU3
Napsal : 28/04/2025 10:54 pm
fester225
(@fester225)
I have that part installed and it has the magnet in it.
Napsal : 29/04/2025 3:23 am
Mike
 Mike
(@mike-35)
Sorry, forgot to post my succcess, reinsalled ball and magnet, unit works, am in he process of moving, MK4 is in storage so haven't been able to play with it recenly
Napsal : 29/04/2025 8:53 am
1 lidem se líbí
Thorsten Lachmann
(@thorsten-lachmann)
If you want to use mmu3 with Nextruder frustration-free? Take a look at my new IAF Idler:
https://www.printables.com/model/1320158-iaf-idler-11-for-prusa-nextruder-with-mmu-unleash
My Printables models including Nextruder improvements: https://www.printables.com/@ThorstenLach_1801966
Napsal : 11/06/2025 4:28 pm
