Interruption of the “Load Filmament” function triggers the MMU overcurrent error
stefan_schober
(@stefan_schober)
Hy all,
I have been using an MK4S with an MMU3 in an enclosure for a few weeks now. Everything is working well exept on function: Each time the printer loads a filmament although no filmament has been preloaded in this slot it gets stuck in an endless loop. The only way to abort this is to press the Reset-button.  (Yes it is silly to give the printer the instruction to load a filmament out of a slot where there is no filmament but it happens. )
After the Reset the Error MMU Overcurrent #26310 occurs. It is not possible to clear this error, not immediately, not after 20min. But after one hour the printer starts without a problem. Than everything is working fine again.
Because of that I have some questions:
  1. Is it possible to adjust the firmeware that after 3 unsuccessful tries of filmament loading the process will be aborted?
  2. Is there a risk of the printer being destroyed due to this incorrect operation?
  3. How can I speed up the process that after the MMU3 Overcurrent error occurs, the printer is faster in operational mode again?
Best Regards
Stefan
Opublikowany : 10/11/2024 9:35 pm
stefan_schober
(@stefan_schober)
RE: Interruption of the “Load Filmament” function triggers the MMU overcurrent error
Good Morning,
today morning evreything is working again. What I register is, when I have the broblem the firmware starts twice. Now in the moning where I don't have this problme the firmware starts only one time and shows after some seconds the home display.
To summ up: 1 hour of waiting don't solve the problem, 6 hours of waiting solves the problem.
Wish you a nice start in this beautifull week
Stefan
Opublikowany : 11/11/2024 6:15 am
sonic bionic
(@sonic-bionic)
I am getting the overcurrent error over and over again. If I wait a bit and turn it back on, it goes away. If I dare reset it, I'll see it again and have to play russian roulette until it clears the error. Very frustrating.
Opublikowany : 11/11/2024 3:22 pm
stefan_schober
(@stefan_schober)
Deleting errors is also a matter of luck in my case.
Today it happend again that I have to press the resetbutton. After that again MMU overcurrent error. Tomorrow morning it will work again.
Frustating is the right description.
Opublikowany : 28/11/2024 6:03 pm
Dan Hill
(@dan-hill)
I am running into the same issue. Hopefully someone will have found a solution soon. I have managed 1 print before this overcurrent issue took over.
Opublikowany : 02/12/2024 7:10 pm
okubi
(@okubi)
It seems that to resolve this issue, the printer’s and MMU’s electronics need to discharge sufficiently (likely the capacitors on the board). Turning it off for an extended period (typically >2 minutes) helps. It appears that the worst thing to do is a reset or quickly turning it off and on again
Opublikowany : 04/12/2024 5:35 pm
katespace
(@katespace)
This also happens with "unload filament". I accidentally hit this option, and after resetting the printer I'm getting stuck with the error.
Opublikowany : 16/02/2025 9:08 pm
