Idler of MMU3 kind of reset mid-loading?
PrinterBigg
(@printerbigg)
Howdy!
I've a weird issue this week. I had no issue at all since my MMU3 (I used Ultimulti mod) upgrade (MMU2S to MMU3).
When I'm loading a filament, the idler kind of "reset" itself after loading at 3/4, so the wheel doesn't grab the filament anymore and the filement stall in the PTFE tube.
I've uploaded a video to show what it does. I included a serial output sample from octoprint.
What could be the issue? PTFE tube too long?
Prusa MK3S+ firmware : 3.13.2 (Revo 6 edition)
MMU3 : 3.0.1
2024-02-21 14:35:06,740 - Recv: T:214.9 /215.0 B:60.4 /60.0 T0:214.9 /215.0 @:31 B@:1 P:0.0 A:31.2
2024-02-21 14:35:06,908 - Recv: echo:MMU2:>Q0*ea.
2024-02-21 14:35:06,912 - Recv: echo:MMU2:<U0 P3*27.
2024-02-21 14:35:06,913 - Recv: echo:MMU2:>f0*21.
2024-02-21 14:35:06,916 - Recv: echo:MMU2:<f0 A*c5.
2024-02-21 14:35:06,917 - Recv: echo:MMU2:>R8*81.
2024-02-21 14:35:06,920 - Recv: echo:MMU2:<R8 A1*98.
2024-02-21 14:35:06,921 - Recv: echo:MMU2:>R1b*9e.
2024-02-21 14:35:06,924 - Recv: echo:MMU2:<R1b A3*57.
2024-02-21 14:35:06,926 - Recv: echo:MMU2:>R1c*88.
2024-02-21 14:35:06,928 - Recv: echo:MMU2:<R1c A3*88.
2024-02-21 14:35:06,930 - Recv: echo:MMU2:>R4*7b.
2024-02-21 14:35:06,932 - Recv: echo:MMU2:<R4 A6a7*7.
2024-02-21 14:35:06,936 - Recv: echo:MMU2:>R1a*f5.
2024-02-21 14:35:06,938 - Recv: echo:MMU2:<R1a Aff49*54.
2024-02-21 14:35:07,809 - Recv: echo:busy: processing
2024-02-21 14:35:07,940 - Recv: echo:MMU2:>Q0*ea.
2024-02-21 14:35:07,944 - Recv: echo:MMU2:<U0 P19*f2.
2024-02-21 14:35:07,946 - Recv: echo:MMU2:>f0*21.
2024-02-21 14:35:07,948 - Recv: LCD status changed
2024-02-21 14:35:07,950 - Recv: echo:MMU2:Retract from FINDA
2024-02-21 14:35:07,952 - Recv: echo:MMU2:<f0 A*c5.
2024-02-21 14:35:07,954 - Recv: echo:MMU2:>R8*81.
2024-02-21 14:35:07,956 - Recv: echo:MMU2:<R8 A0*8d.
2024-02-21 14:35:07,958 - Recv: echo:MMU2:>R1b*9e.
2024-02-21 14:35:07,961 - Recv: echo:MMU2:<R1b A3*57.
2024-02-21 14:35:07,962 - Recv: echo:MMU2:>R1c*88.
2024-02-21 14:35:07,965 - Recv: echo:MMU2:<R1c A3*88.
2024-02-21 14:35:07,966 - Recv: echo:MMU2:>R4*7b.
2024-02-21 14:35:07,968 - Recv: echo:MMU2:<R4 A6a7*7.
2024-02-21 14:35:07,970 - Recv: echo:MMU2:>R1a*f5.
2024-02-21 14:35:07,977 - Recv: echo:MMU2:<R1a Afef1*b4.
2024-02-21 14:35:08,747 - Recv: T:215.2 /215.0 B:60.2 /60.0 T0:215.2 /215.0 @:27 B@:3 P:0.0 A:31.2
2024-02-21 14:35:08,977 - Recv: echo:MMU2:>Q0*ea.
2024-02-21 14:35:08,981 - Recv: echo:MMU2:<U0 F0*c7.
2024-02-21 14:35:08,983 - Recv: ResetRetryAttempts
2024-02-21 14:35:08,985 - Recv: echo:MMU2:>T3*19.
2024-02-21 14:35:09,000 - Recv: LCD status changed
2024-02-21 14:35:09,004 - Recv: echo:MMU2:OK
2024-02-21 14:35:09,007 - Recv: echo:MMU2:<T3 A*75.
2024-02-21 14:35:09,808 - Recv: echo:busy: processing
2024-02-21 14:35:09,993 - Recv: echo:MMU2:>Q0*ea.
2024-02-21 14:35:09,996 - Recv: echo:MMU2:<T3 P5*fd.
2024-02-21 14:35:09,998 - Recv: echo:MMU2:>f0*21.
2024-02-21 14:35:10,006 - Recv: LCD status changed
2024-02-21 14:35:10,007 - Recv: echo:MMU2:Feeding to FINDA
2024-02-21 14:35:10,009 - Recv: echo:MMU2:<f0 A*c5.
2024-02-21 14:35:10,010 - Recv: echo:MMU2:>R8*81.
2024-02-21 14:35:10,012 - Recv: echo:MMU2:<R8 A0*8d.
2024-02-21 14:35:10,014 - Recv: echo:MMU2:>R1b*9e.
2024-02-21 14:35:10,016 - Recv: echo:MMU2:<R1b A3*57.
2024-02-21 14:35:10,018 - Recv: echo:MMU2:>R1c*88.
2024-02-21 14:35:10,019 - Recv: echo:MMU2:<R1c A3*88.
2024-02-21 14:35:10,021 - Recv: echo:MMU2:>R4*7b.
2024-02-21 14:35:10,023 - Recv: echo:MMU2:<R4 A6a7*7.
2024-02-21 14:35:10,024 - Recv: echo:MMU2:>R1a*f5.
2024-02-21 14:35:10,026 - Recv: echo:MMU2:<R1a Afef7*ca.
Napsal : 21/02/2024 2:44 pm
