How to map colors of items to match spool order?
wolph42
(@wolph42)
I hope this makes sense as its tough to explain:
Assume you have an object already colored in the prusa slicer. Lets say:
- Red mapped to spool 1
- Blue mapped to spool 2
- Black mapped to spool 3
now you have the spools already loaded, but in a different order, e.g. black (1); red (2); blue (3).
Is it possible to remap the colors IN THE SLICER? I understand that I can unload the spools and load them in the correct order (red, blue, black), but is that also possible in the slicer software?
(and yes, I'm also aware that i change the colors in the slicer to the correct spool and repaint the object, but im looking for a method where I do not need to repaint, nor need to physically change spool order)
Questa discussione è stata modificata 2 years fa da wolph42
Postato : 02/08/2024 12:56 pm
This is a drawback of relying on slicer-painting for colour - but straightforward if the parts are coloured in CAD.  Quite a few of the CAD-like functions offered by the slicer are there as a last minute stop-gap and only offer a workaround if the user has no access to the design files.
Postato : 02/08/2024 5:04 pm
wolph42
(@wolph42)
RE: How to map colors of items to match spool order?
so, no?! not possible?
Postato : 02/08/2024 11:46 pm
Not in the slicer.
You do have the 'Tools mapping screen' in your LCD menu - sect 9.1.7 in your manual 'though not well explained.
Postato : 03/08/2024 1:25 am
wolph42
(@wolph42)
that will work fine as well, thanks!
Postato : 10/08/2024 10:35 pm
