Firmware 6.1.2 latest - safe to install with mmu3
[Solved] Firmware 6.1.2 latest - safe to install with mmu3
lambert
(@lambert-2)
Hello, I just finished installing an testing the mmu3 on my MK3.5
Because I am new to this mmu(3) thing:
 Can I always install the latest mk3.5 printer firmware or do I have to stuck with the 6.0.4 fw from the mmu3 fw zip until they release a new mmu/printer firmware bundle?
greetings
Christian
Napsal : 24/08/2024 9:32 pm
stevo1957
(@stevo1957)
RE: Firmware 6.1.2 latest - safe to install with mmu3
You  can always install the latest printer firmware.
MMU3 firmware is not updated regularly and will remain compatible with updated printer firmware releases.
Napsal : 24/08/2024 9:42 pm
1 lidem se líbí
lambert
(@lambert-2)
Hi Steve,
thank you very much for you fast!!! answer!!!
good to know, I will upgrade asap!
greetings
Christian
Napsal : 24/08/2024 9:46 pm
Oregun
(@oregun)
I just finished assembling my MMU3 for my MK4, after the first print I upgraded the printer firmware to 6.1.12 and everything still works.
Napsal : 25/08/2024 4:06 am
