Filament Feed Issues
Bomantz
(@bomantz)
I'm having very frustrating issues with filament not properly feeding through the MMU3.  I repeatedly get errors that I have to resolve during printing.  Sometimes the filament does not feed and is chewed within the gears of the MMU.  Other times, the filament is broken as if it was pulled too hard and I have to manually remove pieces from the tubing.
I have a couple of theories but am unsure of the true cause.  I wonder if it's because the filament is a bit old and so has absorbed moisture over time.  I also wonder if the quality of the filament may contribute to my issues.
I'm at the point where I can't get anything to print successfully.  Any insights would be appreciated. Thanks.
Napsal : 06/08/2025 12:34 am
