Coreboxx won't consistantly load into mmu3...
Brad Allen
(@brad-allen)
Most of the time if I pick a short piece of filament and manually feed it into the mmu3 (any 1-5), it almost always loads fine. Almost none of the time will the filament load through the PTFE into the mmu3. Could itbe the ptfe isn't straight enough? A lot of the time it just curls up and misses theload completely...and this is with all 5 different fialaments. No one else seems to have this problem that has a coreboxx (at least that I could find on Discord). Any suggestions? I've been working on this daily for a week now and it's always hit and miss...
Respondido : 27/07/2025 2:15 pm
RE: Coreboxx won't consistantly load into mmu3...
are you using 3mm ID PTFE?
Respondido : 27/07/2025 3:26 pm
Brad Allen
(@brad-allen)
In coreboxx build manual, it said to resuse what came with the mmu3...not sure the size. Also, just this second!! (lol) I tried a different fialment and it seems to wrok on slot one now. What I can't figure out, there are a total of 5 different filaments all from different manufacturers, and they all fail at any given time. I've dried all the filaments in case that made a difference.
Esta publicación ha sido modificada el hace 9 months por Brad Allen
Respondido : 27/07/2025 3:41 pm
scott varney
(@scott-varney)
Miembro
I am running into a similar issue.  It will change colors maybe two to three time and then I getting an error that is can not load.  I end up taking everything apart and then do it again and I get the same results.
Brad were you able to resolve your issue?
Respondido : 01/11/2025 5:12 pm
