Core ONE + MMU3 - no spool join option, no material assignment?
JinPrints
(@jinprints)
Per the title, I've just finished a marathon upgrading my Mk4 to a Core ONE with MMU3 and although it works fine, some of the stuff that I've read or seen the MMU3 setup doing on other models seem to not be there in the Core ONE, notably;
Assigning filament types / colours to each slot seems to not exist in the menus - I can set materials up in the slicer and it prints OK but that means if the setup is ever "wrong" (EG wrong material / colour loaded in a slot Vs what the slicer thinks) the printer won't know there's a problem.
Spool join function seems not to exist - I thought I would be able to load a new reel in a spare slot and have the printer automatically change over when the 1st one ran out? I can't find an option or menu for this anywhere in the printer OR the slicer.
Is this right? Have I missed something?
I've just built it this week so all the firmware is the latest versions and all the tests and calibrations were passed.
Publié : 30/10/2025 8:57 pm
1 personnes ont aimé
RE: Core ONE + MMU3 - no spool join option, no material assignment?
on the filament choice screen turning the knob one way allows you to change filament types, turning the knob allows you to substitute filament allocations, and do spool join!
Publié : 30/10/2025 9:01 pm
JinPrints
(@jinprints)
What filament choice screen?
Posted by: @joantabb
Publié : 30/10/2025 10:00 pm
Richard3D
(@richard3d)
maybe someone can make a video and show exactly how to do this.
PrusaCOREOne+
Publié : 31/10/2025 3:06 am
JinPrints
(@jinprints)
Thanks for not actually helping - what are forums for after all? 🙄
I've found the screen - it appears when you hit "print" but since my PC is not next to the printer I had not seen that screen when uploading print jobs as I don't run from my PC to my printer every time I hit print... perhaps foolishly I had assumed it might be reachable through the menus.
Posted by: @richard3d
Publié : 31/10/2025 11:06 am
You have to visit the machine between/before every print to clear the print sheet and load fresh, dry filament in any case so unless you are running a print farm with employees to do the grunt work (in which case you train them) it's pointless starting prints remotely.  It's my opinion the the recent rise in stringing problems on the forum is due to misuse of remote control software.
Publié : 31/10/2025 7:54 pm
JinPrints
(@jinprints)
I clear the machine after each print so it's always ready to go - as I say, the PC is not by the printer and given how long it takes to actually warm up & start printing I have not been rushing from PC to printer.
As I said, it feels odd that this screen only comes up when starting a print and there's no menu to tell the printer what spools are loaded when it's idle.
Publié : 31/10/2025 8:03 pm
?  The machine knows what you told it on loading - you should never leave a printer idle when loaded; it should either be printing or cleared and shut down.
Publié : 31/10/2025 9:50 pm
JinPrints
(@jinprints)
Are you saying you think I should unload all the filaments from the MMU and power the printer off every time I'm not actively printing something?
Publié : 01/11/2025 12:22 pm
Of course.
Publié : 01/11/2025 11:05 pm
Blindbatts
(@blindbatts)
Membre
I too, want improvements to this feature. The MMU3 feels like a hacked add-on rather than an integrated component of my core one.
I have a coreboxx on top of my printer, with a semi-smart dehydrator heater for the box. I always have 5 spools loaded and ready to use. I send the prints from my computers or phones remotely, the same way I sent them with my previous printer that had octoprint. I clear and clean my print bed after the print is completed so it's ready to use by my wife or I for the next thing.
It would be wonderful to have the option to enable spool join DURING the print. Locally on the printer would be fine.
2025 Core one kit, buddycam, one+ upgrades, Coreboxx premium w/semi-smart.
Publié : 31/12/2025 8:10 pm
Nonoobybut
(@nonoobybut)
Membre
  • Hi @all i had the same problem: the spool join is hidden if you upload it through connect as instant printing. You have to select the option 3: just upload it to the printer. Now you will see a little minipic of your print and press print: now it shows the filament menue with spool join and then you have to twist left until it goes up to the filament, then press knob and enter how many spools you want to join by selecting them. But: It doesn‘t work very well if there is a little hook at the end of the first spool‘s filament. The MMU will have a jam when retracting it.
    Hope this helps
Publié : 16/02/2026 8:18 am
PxT
 PxT
(@pxt)
Membre
I was struggling with this as well and I think the interface is not very intuitive at all. For anyone finding this thread like me - Prusa has a video posted which shows exactly how to make it work. The video demonstrates on an XL but the process is the same on Core One with MMu3
Publié : 25/02/2026 12:05 am
