Core ONE + MMU3 - no spool join option, no material assignment?
JinPrints
(@jinprints)
Per the title, I've just finished a marathon upgrading my Mk4 to a Core ONE with MMU3 and although it works fine, some of the stuff that I've read or seen the MMU3 setup doing on other models seem to not be there in the Core ONE, notably;
Assigning filament types / colours to each slot seems to not exist in the menus - I can set materials up in the slicer and it prints OK but that means if the setup is ever "wrong" (EG wrong material / colour loaded in a slot Vs what the slicer thinks) the printer won't know there's a problem.
Spool join function seems not to exist - I thought I would be able to load a new reel in a spare slot and have the printer automatically change over when the 1st one ran out? I can't find an option or menu for this anywhere in the printer OR the slicer.
Is this right? Have I missed something?
I've just built it this week so all the firmware is the latest versions and all the tests and calibrations were passed.
Opublikowany : 30/10/2025 8:57 pm
RE: Core ONE + MMU3 - no spool join option, no material assignment?
on the filament choice screen turning the knob one way allows you to change filament types, turning the knob allows you to substitute filament allocations, and do spool join!
Opublikowany : 30/10/2025 9:01 pm
JinPrints
(@jinprints)
What filament choice screen?
Posted by: @joantabb
Opublikowany : 30/10/2025 10:00 pm
Richard3D
(@richard3d)
maybe someone can make a video and show exactly how to do this.
Prusa Core One
Opublikowany : 31/10/2025 3:06 am
JinPrints
(@jinprints)
Thanks for not actually helping - what are forums for after all? 🙄
I've found the screen - it appears when you hit "print" but since my PC is not next to the printer I had not seen that screen when uploading print jobs as I don't run from my PC to my printer every time I hit print... perhaps foolishly I had assumed it might be reachable through the menus.
Posted by: @richard3d
Opublikowany : 31/10/2025 11:06 am
