Changing the distance the filament gets retracted during filament changing
2btyler@gmail.com
(@2btylergmail-com)
I would like to reduce the distance the filament gets retracted when changing filament colors on the MMU3. Currently the filament gets pulled back just enough to be out of the tube just before the SPinda, and then the filament curves out when being pushed through instead of loading correctly. I have the buffer assembly set up
Napsal : 22/03/2025 7:57 pm
2btyler@gmail.com
(@2btylergmail-com)
RE: Changing the distance the filament gets retracted during filament changing
In reading the vary similar posts, it seems if I change the bowden length by a bit it might work to change the retraction length and thus keep the filament in the tube just prior to the SPinda...
Napsal : 23/03/2025 3:48 pm
2btyler@gmail.com
(@2btylergmail-com)
Whelp, not sure what happened but it is working all of a sudden.
Napsal : 23/03/2025 7:23 pm
