Beeps and the “Filament Change 04508” message at the end of the multicolour print
I have MK3S+ with MMU3 and all my successful multicolour prints end with “Filament Change Prusa io/04508” message on LCD and continuous beeping. The g-code is generated with PrusaSlicer 2.7.2, which has the standard preset End-G-Code that is in the MMU3 “Printer Setting”. Also, both MMU3 and the printer have the latest firmware. The only way stop the beeping is to load a filament or Reset the printer. Is this a normal behaviour? Or, is there another way to avoid the “Filament Change io/04508” message and the beeps at end of a multicolour printing?
Thanks
Publié : 26/03/2024 5:27 am
