SVG into Prusa slicer (adobe illustrator )
Bh_singh
(@bh_singh)
I was having the issue when adding a svg,  it was only using the outline of the shape but missing all of the inside details.
The fix in illustrator was to select shape and make it a compound path (right click , make compound path)
I have found that filling shapes makes it easier to smart fill
Apologies if there are other better solutions out there, all I found was that it is luck whether it imports correctly or manually move all parts of the svg into position
Hope this helps someone out
Napsal : 14/11/2025 10:12 am
1 lidem se líbí
