Single Material Mode - MMU3 with Prusa Mk4
Pagina 2 / 2
tsetse fly
(@tsetse-fly)
RE: Single Material Mode - MMU3 with Prusa Mk4
Using the filament mapping but MMU3 not switching to other spool position on print.
Prusa Slicer 2.9
  - Using non-MMU profile
MK4S
  - MMU3 toggled "on"
  - MMU3 has material 5 loaded
  - Filament mapping pops up before print, select  1.material on left side and material 2 on right side column, Replace button, Print button.
I was expecting the MMU3 to change to material 2 but it just uses material 5 which was loaded prior to printing. Should the MMU3 switch to material 2 (isn't that the point of the filament mapping steps) ? Something in the setup I have listed?   MMU3 is on, filament mapping coming up.
 - thanks for any insight
Postato : 10/01/2025 12:56 am
tsetse fly
(@tsetse-fly)
Restarting printer seemed to fix this (should have tried that first....)
Postato : 10/01/2025 4:54 pm
swill01
(@swill01)
You can also just turn the knob to the left and it will go across the bottom buttons and then up to the 1.PC as the last stop. Select it and then change the filament.
Postato : 24/01/2025 12:02 pm
Pagina 2 / 2
