MK3S Upgrade to MK4 incl. MMU3 instructions?
Spawnpi_01
(@spawnpi_01)
Hello,
I would like to convert our MK3S with the MK4 Upgrade Kit. I would also like to use the MMU3 directly on the new MK4. Are there any assembly instructions that go well with the MK4 upgrade instructions so that the MMU3 can be fitted directly without any extra work?
thx Gerrit
Opublikowany : 20/08/2024 4:33 am
ironfan72
(@ironfan72)
RE: MK3S Upgrade to MK4 incl. MMU3 instructions?
I haven't seen any. In fac the MMU3 instructions state that you should make sure your Mk4 is working well in "regular mode" before adding the MMU3. I'd also recommend making sure your Mk3S to Mk4 upgrade is working fine first otherwise if you have a problem you may not know exactly where in the upgrade processes it lies.
Opublikowany : 22/08/2024 8:30 pm
Spawnpi_01
(@spawnpi_01)
I feared it 😉 - but you're right, it does make sense to do it step by step. I just upgraded our other MK3S to MK4 last week and thought I could save some time on the second one, where the MMU3 is also to be installed - thx
Posted by: @ironfan72
Opublikowany : 23/08/2024 6:13 am
Shafique
(@shafique)
I understand the hesitation 😉, but you're right—taking it step by step is the best approach. Since you just upgraded another MK3S to MK4 last week, it makes sense to follow the same careful process for the second one, especially with the MMU3 installation. Thanks!
Opublikowany : 24/08/2024 7:36 am
