How to make loading filament to MMU3 easier?
annabrego
(@annabrego)
Hello,
I recently got my MMU3 for the MK4, and I really like it so far. My biggest issue is loading filament. If the filament is too curled, it veers off and slips out the side. Plus, jamming filament is frustrating. I always cut my filament tips to a point, but getting the filament to align properly with the hobbed gears and feed can be a hassle. Has anyone with an MMU found a way to make this process more foolproof?
Posted : 23/11/2025 9:47 am
LarGriff
(@largriff)
In addition to sharpening (or rounding) the tips, the main trick is to make sure the first 4” (100mm) is straightened.  There are a few “straighteners” on Printables.com but I just use my fingers.
Also, if you unload a spool from the MMU, don’t cut off the tips as they are likely still well formed and will load easier the next time you use it.
This post was modified 4 hours ago by LarGriff
MK4S/MMU3
Posted : 23/11/2025 2:56 pm
