blobs on purge Tower
Jack Renders
(@jack-renders)
This is the second one now after a bunch of successful color changes it does this sometimes and it leaves a little pancake of filament in the drivegearbox .any ideas?
Postato : 16/09/2025 11:08 pm
2 persone hanno apprezzato
rosic
(@rosic)
RE: blobs on purge Tower
Me and my colleague have the same issues. We tried everything you can think of. Nozzles, maintenance, speed, temperature, more passes during wiping, etc. etc. Prusa team will tell you to use multimeter to measure termistor. Just another bug/error that nobody is willing to fix...
I started discussion here: link
Postato : 24/09/2025 9:07 pm
1 persone hanno apprezzato
Henk H
(@henk-h)
I've been batteling the blob for 2 weeks now. I tried all the tips i could find and did not resolve the problem. I've been printing creality PETG, because it prints fine and is cheap. After i built the MMU3, problems started like i said. Today I was testing (again) and decided to increase the temp above creality's spec ( 130c). I went to 165C on all 5 colors and was amazed by the result! Blob is gone,and i am amazed by it.
I hope some of you guys get the same results as i did.
Good luck!
Postato : 20/10/2025 6:48 pm
JGeiger2024
(@jgeiger2024)
Henk - What temperature did you go with? Surely not 165C
Postato : 22/10/2025 8:24 pm
LarGriff
(@largriff)
Posted by: @henk-h
Surely you mean 265C, not 165C.
Questo post è stato modificato 6 months fa da LarGriff
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Postato : 28/10/2025 2:39 pm
Henk H
(@henk-h)
You're right. Stupid mistake.
Postato : 28/10/2025 6:07 pm
Henk H
(@henk-h)
I went with 265C, and I am sorry for the mistake.
Postato : 28/10/2025 6:08 pm
Alienbliep
(@alienbliep)
I find this problem everywhere on forums.
I have the same issue. Big print, small print everytime i get multiple blobs.
And a lot of nasty noise when it passes it when the last wipe.
It is where the nozzle halts and waits for new filament.
Why isn't bed lowered directly after the first unload wipe? It can be done.
Everybody knows when you put an soldering iron into plastic the stuff gets deformed.
I dont use the mmu often because of this reason.
I only load 5 spools in an drybox and this way print my project in sections.
Questo post è stato modificato 6 months fa da Alienbliep
Postato : 12/11/2025 6:28 am
Jack Renders
(@jack-renders)
everyone, since i started using CHT nozzle i have had no blobs. I mainly got the blobs while using non CHT 0.6 and have had less problems using CHT
0.4 or 0.6 nozzles. maybe this helps any of you
Postato : 12/11/2025 10:57 am
Alienbliep
(@alienbliep)
Ok. Maybe it won't ooze during the pause there?
Anyway prusa recommends this nozzle so i use it. I see no really performace difference between cht and normal. Price is even beteer and i don't care for the minutes i win.
Postato : 12/11/2025 11:39 am
iKriz
(@ikriz)
Utenti
Just came across this issue aswell.. kinda new to this whole multi material printing.. blob caused a layer shift for me, i'm guessing its a configuration issue in the project.
Which of the million settings is it? i'm guessing something to do with purge volume?
Minimal purge on wipe tower? my core one does a purge directly after loading the filament.. then it proceeds to blob more in the wipe tower. So theres double purge it seems. I have multiple extruders set with Single extruder Multi material enabled.
Questo post è stato modificato 5 months fa da iKriz
Postato : 11/12/2025 10:50 pm
iKriz
(@ikriz)
Utenti
UPDATE: Found the culprit! after hours of staring at gcode...
Print Settings > Multiple Extruders > Wipe Tower > Extra flow for purging
This is set by default to 250% !!!!! who needs that much filament in a wipe tower? i've set it to 100% for now...
Postato : 12/12/2025 12:11 am
mnentwig
(@mnentwig)
you might give this a shot (not sure I fully understand the mechanism behind it, the only blobs giving me headaches are large binary objects 🙂 )
...the following piece of G-code in "Printers" / "Custom G-Code" / Tool change G-code:
G1 Z+10 F10000; avoid melting into wipe tower (-mn)
see here: https://forum.prusa3d.com/forum/postid/773816/
Postato : 12/12/2025 10:30 am
