Assembly manual for upgrade kit?
mavu
 mavu
(@mavu)
I don't know which manual to follow. I bought the MMU2s to MMU3 upgrade kit.
I can't find a assembly manual for that, i see only:
- Original Prusa MMU3 Assembly
- Original Prusa MK3S+ MMU3 upgrade kit to MK4/MK3.9 Assembly 1.0
There does not seem to be a "Original Prusa MMU2s upgrade kit to MMU3" assembly manual.
could anyone give me a link, or tell me which to use?
I'm lost.
Also, I find it really hard to tell which printed parts I have to print for this upgrade, but maybe that will be listed in the assembly manual when i find it.
Best Answer by kobbler:
https://help.prusa3d.com/guide/1-introduction_400300
You are looking a the right one. Read the start and you will see...
Welcome to the MMU3 assembly guide! There were several generations of the Original Prusa Multi-Material printing solution. Verify you are looking at the correct guide for your MMU unit and your printer.
MMU1 for MK2 and MK2S printers (introduced in 2016-2018)
It used four separate extruders feeding one nozzle.
MMU2 for MK2.5 and MK3 (2018-2019) Five filaments feeding one direct-drive extruder.
MMU2S for MK2.5S, MK3S, MK3S+ (2019-2023)
Introduced a chimney on the extruder with the IR-filament sensor.
And finally, the current model:MMU3 for MK3S+, MK3.5, MK3.9 and MK4 (2023-now)
MMU3 is the one we will be dealing with in this guide.
Respondido : 30/04/2024 7:40 pm
kobbler
(@kobbler)
RE: Assembly manual for upgrade kit?
Respondido : 30/04/2024 9:29 pm
1 les gusta
mavu
 mavu
(@mavu)
Thank you, indeed you just need to scroll down quite a way and then it splits off to assembly / upgrade kit.
Respondido : 30/04/2024 10:37 pm
