adjust MMU3 to work with MK2.5S
nhand42
(@nhand42)
A few months ago this appeared on the Prusa blog following the MMU3 announcement.
You might have noticed that we’re not specifically mentioning Original Prusa i3 MK2.5, Original Prusa i3 MK2.5S, Original Prusa i3 MK3 and Original Prusa i3 MK3S. Due to production and processing capacity, we have decided not to prepare specific packages for these printers. However, do not worry, we’ll publish an article in our Knowledge base which will describe how to adjust the Original Prusa MMU3 designed for MK3S+ to make it work with your Original Prusa i3 MK2.5 / Original Prusa i3 MK2.5S / Original Prusa i3 MK3 / Original Prusa i3 MK3S printer with some simple steps.
Fast forward today and this article hasn't appeared. Does anybody know if Prusa has walked this one back? Is there a blog post that says they've changed their mind and the MK2.5S will never work with the MMU3?
Reason I ask is I've already done much of the work to convert my MMU2S into an MMU3. I'm waiting for the article so I know what electronic/wiring changes are necessary to get it working with my MK2.5S.
NB: I'm aware of https://help.prusa3d.com/article/mmu3-compatibility_470808 and although the MK2.5S isn't "officially compatible" and "not optimized" that doesn't rule out it being possible.
Napsal : 12/04/2024 6:32 am
Nain
 Nain
(@nain)
RE: adjust MMU3 to work with MK2.5S
Just want to add I would've bought the upgrade for my Mk2.5 if this was explained anywhere online
Napsal : 29/11/2024 3:16 am
